So I built a computer for going over to uni about a year ago and since ive been using it, it always has this one problem. When the loading screen for windows finished it goes to a blank screen and stays like that and wont go to the windows login screen.
Sometimes you have to restart the computer 2-3 times before it will go to the login screen. But now since ive been back from uni I havent used it before the summer and everytime i try to get to the login screen it just goes blank
Ive tried both DVI ports on the G-card and ive even taken the G-card out and used the VGA thats on the motherboard and it still does it :'( I dont know what else to try. Would it be the motherboard itself thats the issue??
Many thanks,
Lighter.
Many thanks,
Lighter.
