My Documents Help
29 Sep 2004
Wilt of the Shire
Is there any way to turn off the documents folder in the start menu? It's to stop the Mrs asking questions when I've been visiting "training" sites and I forget to clear them :)
Right-click start menu, click properties or customize and somewhere there you can remove.
What do you mean with "training" sites? ;)
I can only find the option for expanding the My Docs folder and not an option to remove it. I'm using the classic start menu if that makes a difference.
Training Sites = Healthy non-work sites :)
Maniac618 said:
oh my god you dirty man, just give the wife a good seeing to instead.
I do and regularly but it's always nice to look at the grass across the street:)
just create separate user-accounts for yourself and your wife, that way your xxx-site visits will go unnoticed... ;-)
