- 27 Jul 2005
- The Orion Spur
as in title, my [email protected] should be allright at thoese temps should'nt it ?, when do these chips start to throttle ?
Zefan said:Could be a dodgy motherboard sensor? I know old athlon boards were dire for this, you basically couldn't trust anything apart from a probe.
The only thing I can think of is if you've got it on silly volts or it's concave.
WJA96 said:That's fine. It won't start to throttle until you hit 75-80C and it will shut down to protect itself at about 85C.
Tooks said:That temp is fine, especially as it's a load temp.
85c on the E6300 is the temp you have to worry about.
Ok, so you may not have the coolest running C2D on here, but so what? It's well within it's tolerance.
