Hi
After much delibration and thinking.. i have finally got my final spec.. just wanted to know if it will be ok and everything will fit fine.. comment back if you will please..
Asus P5N-E SLI nForce 650
Tagan TG530-U15 530W ATX2.01 Easycon SLi Compliant Modular Silent PSU
Lian-Li PC-7 PLUS
Noctua NH-U12F
OCZ 2GB PC2-6400 Duel Channel Platinum Revision 2 XTC Series DDR2
Gainward BLISS GeForce 8800GTS 640MB
there it is... will it all work together.. please tell me.. thanks
Note - do i need 640MB GTS if playing at 1280 x 1024 ?
Thanks
edit - just in case your wondering. i have processor, hard drive and dvd drive
Lian-Li PC-7 PLUS
Noctua NH-U12F
Thanks
SATA is the standard now. The DS3P is fully compatible with the Noctua -
