My first 6600 overclock
24 Aug 2005
Uranus
Just overclocked my 6600 conroe to 3.2ghz stock volts 350 fsb x 9, mem at 4,4,4,12 2.1v 350mhz, temps 60c full load with a ninja is this ok?
orthos stable for 4.5 hours, is that enought time? What should i try for next?
3.15 is about the max you will get stable on stock volts and even then I'd be suprised if you get it 100% stable above ~3.09 on stock... but then not all CPUs are the same quality...
If you can pass atleast 300% memtest or 3 passes memtest86+, run through 3D marks 06 without issues and a 32Mb superPi as well as 4.5hours priming you should be stable enough...
yeah, thats a bit too warm.
ps. my freezer 7 with extra fan cools nicely. (stock fan is very quiet but i needed more air)
