After being 'chastised' for not Over-clocking my AMD64 FX57 and Custom Watercooling set-up, I still do not trust myself with setting FSB/RAM Dividers/setting Voltages for CPU or NB.
Specs are
FX57 with AquaXtreme MP-05 Limited Edition SE (Delrin) waterblock
Sapphire X1900xt-x with AquaXtreme MP-1 waterblock
Asus A8N32SLI Deluxe (BIOS Version 1303)
2x1GB Corsair XMS3500LL TwinX (PC3200) @ 2/3/2/6
Housed in LianLi V2000B - with 1/2" tubing/D5 Vario/PA120.2 + 2 Panaflo M1A 120mm fans @ 7v
Therefore, taking the 'cowards' way out I have overclocked using Asus's OC Profile by selecting an 8% Overclock (couldn't get 10% to boot into Windows)and ATI Tool for my X1900XT-X.
This has resulted in changing settings as follows :
CPU - Core Speed increased from 2800Mhz to 3024 Mhz ( Multiplier = 14 x 216.0 HTT) Voltage = 1.456v
RAM - Frequency 216.0 Mhz, FSB: DRAM CPU/14, CAS#Latency 2.0 clocks, RAS# to CAS# Delay 3 clocks, RAS# Precharge 2 clocks, Cycle Time (Tras) 6 clocks, Bank Cycle Time (Trc) 11 clocks, DRAM Idle Timer 16 clocks, Command Rate 1T.
GFX - Overclocked using ATI Tool from stock 648/774 to 735/850.
System been tested using SP004 and passed both Small FFT's test for CPU up to 10K and Blend Test for Stress on both CPU+RAM 1024k, Runs both 3DMark05/06, and Gaming.
Results
SuperPI (1M) reduced from 30 to 28 seconds
3dmark05 - Score increased from 12,061 to 13,148
3dmark06 - Score increased from 5404 to 5909
Temps shown on Asus Probe had CPU at 36c, MB 37cand ATI Tool GPU at 36c
Is this any good or what would a reasonable overclock be using the 'normal methods' ?
Specs are
Results
