Hi everyone
I have just upgraded all my pc components and thought id give overclocking ago. Everything seems to be running fine i just want someone who knows more than me to answer a few questions i have and to check if everything looks good, ill include as much info as i can.
Computer specs
Core2Duo E6300 o/c @ 2324 Mhz with original intel fan
8800 GTS 320mb pre-overclocked at 600/1800
1gb (2x512) Corsair XMS2 pc5400
Gigabyte 965P-S3
Hiper 580W Power Supply
My cpu temp is 55 idle and 65 under 100% load using TAT, how much higher would you recommend pushing this if any? Despite reading a lot about it im still not sure what settings in the bios are correct for my memory. Am i right in setting the timings to 4-4-4-12 and changing the memory multiplier to 2 ? One more thing is when i run 3dmark06 the 2 cpu tests run really slow, probably about 1-2 fps, also the screen resolution changes for these 2 tests, is this normal ? My score was 8452, is this high/low/average for my specs?. Ill include a screenshot with some more info off various programs. If anyone can see anything which i can improve please tell me.
Thanks
Computer specs
Gigabyte 965P-S3
Thanks
