My first build finished but...
3 Oct 2011
I'm not sure what option to select.
I've inserted the drivers disk that came with the mobo and it's asking to Select source:
1. Generate the RAID/AHCI driver diskette for Intel Z68 Chipset
2. Generate the AHCI driver diskette for Marvell SATA 3.0
3. Exit
Does it even matter? I'm guessing they both need generating?
Lets start from the beginning.
You have built the PC and havent put anything on the HDD yet?
You have it working and can access the BIOS?
PC built, nothing on HDD, it's working but not sure about access to BIOS.
Asus splash screen comes up for about a tenth of a second then I get: "Reboot and select proper boot device or insert boot media in selected boot device and press a key"
Is there not a sticky or thread for ultimate noobs like me??
Install Windows first then worry about drivers. You may need to change the boot priority to boot from the optical drive.
Good, I linked to a video above to show most of the rest.
Is this a intel build? is the SSD on a intel controlled SATA port and not a crummy Marvell one?
What board is it?
I'll try the video thanks!
It's an intel build on an Asrock Z68 Extreme4 Gen3 mobo. Not certain if it's Marvell or Intel, very new to all this stuff, sorry! How would I find out?
