My first build :/ Is this card okay?
23 Feb 2009
Woking
Hey this is my first build ever :o!
im new to these forums and just wondering if you think the Sparkle 9800GTX+ 1gb is a good card to use with my ASUS m3n78 MOBO and im using an AMD Athlon 64 6000+ 3GHZ
If not then please could you recommend a nice one :D (that supports Blu-Ray)
Thank you very much :D
Whats your spending limit on a card??
For a little extra than the 1GB 9800GTX+, the GTX 260 is considerably faster.
Hmm well i guess i could go around £200 maybe a tad more? How much are the GTX 260's roughly?
Thanks :D
Neat awsome its in my pricerange :D
Will this be able to handle programs such as Photoshop CS4 and Maya unlimited well too?
Thanks for your help :D
AH right, what usually makes them really slow then? the CPU? because thats the reason im building a new comp this one i think is just outdated using a 2.0GHZ :/
Ah thanks, well my cpu is 1ghz over my old one then already and now i have 2more gb of ram and this hard drive is just well lame :D
Yeah CPU will help more with Maya and that. A quad-core really helps for that kinda work.
The best CPU's by far for that type of software is Intels core i7's CPU's. The cheapest one (i7 920) is about £220. But then your'd have to get a different motherboard and more expensive DDR3 memory..
I wouldn't bother with the Athlon 64, it's old now. If the i7's are too much then i'd go for a Intel Core 2 Duo or AMD Phenom II Tri-Core.
AH i see :( ive already got my new mobo and cpu now bah, on my next build then i guess ill be using intel :D thanks again for your help :D
