Hi All,
This is my first build log and I thought I would document and share my experience with you all
Main Components:
ThermalTake Core V71 Case
ThermalTake Toughpower 2000w Power Supply
MSI Z87-GD65 Gaming Motherboard
R9 290X Lightning Graphics Card
Intel 4770k CPU
Vengeance® Pro Series — 16GB (2 x 8GB) DDR3 DRAM 2400MHz
Liquid Cooling Components:
D5 Photon 270 Reservoir/Pump Combo
D5 Aluminium Screw Ring (Black)
RayStorm CPU WaterBlock
G1/4″ to 7/16″ ID, 5/8″ OD Compression Fitting (Black Chrome) V2
EK-FC R9-290X Lightning - Acetal+Nickel
Mayhems Ice Dragon Nano Fluid 1L
XSPC Highfelx Hose
*****EDIT*****
I forgot to add the rads lol, see below:
EX240 Dual Fan Radiator
AX240 Dual Fan Radiator
4x XSPC 120mm 2000RPM Fan
Cables:
BitFenix 24-pin ATX extension 30cm - sleeved white / white
BitFenix SATA 3 Cable 30cm - sleeved white / black
BitFenix Molex to SATA Adapter 4x 20 cm - sleeved white / black
So there you have my list of components, apart from HDD's which im pulling from my old machine. I have added some pics below and there will be more to follow
Images:
http://imgur.com/a/RAjsY
Main Components:
Intel 4770k CPU
XSPC Highfelx Hose
*****EDIT*****
Cables:
Images:
can't wait to see some more
Will be following this. Subbed
