Hi guys,
Im building my first PC, not bothered about overclocking it just want a fast Pc with good graphics that will last me a good few years and then some.
Here is some things i have saved in my checkout at Oc,
CA-054-LL Lian-Li PC-7 PLUS Black Aluminium Midi-Tower Case (No PSU) (CA-054-LL) £48.99
MY-058-GL GeIL 2GB (2x1GB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) (MY-058-GL) £164.99
2 x CD-076-SA Samsung SH-W163 16x16 DVD±RW Serial ATA Dual Layer ReWriter (Black) (CD-076-SA) £47.98
CA-005-HP Hiper HPU-4K580-MK Type R 580W Modular ATX2.2 PSU - Black UV (CA-005-HP) £54.99
CP-128-IN Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN) £195.99
GX-014-EA EVGA GeForce 7950 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (GX-014-EA) £189.99
KB-069-LG Logitech G5 Gaming-Grade Laser Mouse - Retail (KB-069-LG)£36.99
2 x HD-023-WD Western Digital Caviar Special Edition 80GB 800JD SATA-II 8MB Cache - OEM (HD-023-WD)£55.98
MB-108-AB Abit AW9D-MAX Intel 975X (Socket 775) PCI-Express DDR2 Motherboard (MB-108-AB) £129.99
Subtotal £925.89
VAT £162.04
Total £1,087.93
Is this system gonna be compatible with the case and are all the parts gonna be compatible with the board.
If you can think of better replacements then please do say them although ive reached my max spend so please try not to list things of a higher price.
Also can you tell me if this is a good gfx card for my needs, will probs only go as high as 1024 x 768, thats all im used to now, may go a little higher. Do i need 512mb? cheers please suggest replacements.
Any help from anyone is very much appreciated.
Saved up £1100 and I wanna get my first build right first time. If theres anything else I may need that isnt listed above then please say.
Thanks in advance,
Lee.
Subtotal £925.89
VAT £162.04
Total £1,087.93
Thanks in advance,
Lee.
