1 Sep 2011 at 16:31 #22 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare Get one later, use the intel item for a while.
1 Sep 2011 at 16:36 #23 martrimo martrimo Associate OP Joined 30 Aug 2011 Posts 171 k do you know any cheaper - better cases or is this fine. (Got a spare 1Tb hard drive at home)
1 Sep 2011 at 16:39 #24 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare I can suggest cheaper cases but they have less fans as standard. The antec 100 is solid choice.
1 Sep 2011 at 23:59 #25 martrimo martrimo Associate OP Joined 30 Aug 2011 Posts 171 Zalman Z9 Plus Tower Case or antec 100 best fit and best performance cooler
2 Sep 2011 at 00:02 #26 stulid stulid Caporegime Joined 17 Jan 2010 Posts 66,731 Location weston-super-mare The Zalman Z9 is better. It has more fans as standard, a fan controller and temperature probe and digital readout.
2 Sep 2011 at 00:51 #27 Bwaaa Bwaaa Associate Joined 23 Apr 2011 Posts 220 I may be murdered for this suggestion but is a 2500k REALLY necessary at this pricepoint?
2 Sep 2011 at 00:59 #28 Jony27 Jony27 Soldato Joined 15 Aug 2010 Posts 8,892 Location N. Ireland Bwaaa said: I may be murdered for this suggestion but is a 2500k REALLY necessary at this pricepoint? Click to expand... yes, as long as it fits the budget, its worth it.
2 Sep 2011 at 01:23 #29 martrimo martrimo Associate OP Joined 30 Aug 2011 Posts 171 One last question will all this stuff fit into the zalman z9
2 Sep 2011 at 10:56 #30 Jony27 Jony27 Soldato Joined 15 Aug 2010 Posts 8,892 Location N. Ireland martrimo said: One last question will all this stuff fit into the zalman z9 Click to expand... yes, no problemo
2 Sep 2011 at 15:54 #31 tigerstyle tigerstyle Soldato Joined 18 Oct 2002 Posts 8,968 Location UK wow that case got expensive! Good to keep a track of things with screen captures like that
