My first C2D overclock - hows it look?
Man of Honour
20 Sep 2006
E4300 with Noctua NH-U12F cooler
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz
Asus P5N32-SLI mobo
Had it at 3.6 iirc yesterday, but within 2 mins of Orthos running the system restarted. I think I got a bit carried away so I've put it to what it is now and am doing a long stability test. Seems fine so far. Max temp I've seen under load is 52 deg C, and it idles at around 22 each core with no stepspeed.
Looking at the above two screenshots, I've got a few questions which I'll list:
  • What is the max temperature I should start to get worried about? I know Orthos stresses the system far harder then anything I'd do on a day to day basis. I set myself a limit of 55 deg C. Is that OK? Or could I push it a little more?
  • Could the RAM be pushed harder?
  • What's the max safe VCore I should run considering the above temps?
  • Overall, is it a good overclock? Would there be any point in placing further strain on the system by looking for an extra 200MHZ or so out of the CPU? Or should I now concentrate on the RAM now that the CPU seems settled at 3.2 GHZ?
Overall I'm actually sat here laughing that a chip that normally runs at 1.8GHZ is sat in my PC at 3.2GHZ under stress and is fine! Reminds me of my (very) old AMD Athlon Mobile 2400+ chip that loved having its neck ringed!
Nice stuff mate. :)
Got the same CPU and mobo as you except using OCZ 2GB Kit (2x1GB) DDR2 800MHz/PC2-6400 CL 4-4-4-15 PLATINUM, and one of those big Zalman flower coolers.
Trouble is, ive never really oc'd before, i managed to get it to 2.1ghz but if i raise the fsb anymore then it doesnt boot.
Any tips?
Shot at 2007-07-14
v0.94 of coretemp under reads E4300 temps by 15c, so give v0.95 a try.
60c load would be more realistic I think.
Yeah got.95 now, showing about 10-15 deg higher now. I've also changed the RAM to 4-4-4-15 2T @ 890 MHz. Running fine.
Servo said:
From your screen shot, you are not duel priming, download this and try mate...
orthos
I was mate, the other was minimised in the taskbar and I couldn't be bothered showing two windows with the same info.
