Hello, asked quite a lot of questions when putting my shopping list together so I thought I'd put back in the form of a log that may be of use or interest to somebody. Getting the shopping list posted in first as I notice the mobo has already been replaced by a Z97 version so I've had to cut and paste a bit from my other thread. Alongside the below I bought over from my previous PC an MSI 7950, Seasonic G550W and a PCI Wifi card. This list totals £743.85 but I can't remember what I ended up paying, I know the memory was on offer at the time and cost less etc.
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £169.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £119.98
1 x Corsair Hydro H80i High Performance Liquid CPU Cooler £74.99
1 x Aero Cool Dead Silence Gaming Orange Mini Tower Windowed £72.95
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLD38G2400HC11CDC01) £65.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £59.99
1 x Gigabyte Z87M-D3H Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard £82.99
1 x Samsung SE-S208DB/TSWS External Slimline 8x DVD-RW (TV Connect) - White £21.98
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
Not really much to say about the choices, processor was the best price/performance at the time. SSD was a good price for the size, 120Gb wasn't really enough when something like Titanfall takes around 50 up. Cooler was hardest choice between it and some air coolers. Had information overload but thought I'd give it a try. Case was nice looking and preferred the layout of the mobo laying down rather than upside down on the side as in the Bitfenix. Memory was on offer at the time, didn't colour match but red/orange is close enough for me and I found a red external drive to go alongside as a half hearted attempt at a theme. HDD best price I found for the size/speed. Mobo was I think the cheapest of the MATX boards I looked at and had what I needed with decent enough reviews. External drive was for the rare time I get bought a CD to import or for Windows install etc, probably go away in a drawer 90% of it's life. Went for Windows 8 as it's newer, not too fussy if I don't get along with it as I don't tend to root around on things outside the regular games/music/net etc.
Have some pics to sort out and some sort of narrative that I'll put together another day.
Bye for now
YOUR BASKET
Bye for now
Look forward to seeing it progress
. Fortunately for me before I had completely wrecked it this then showed there to be a cover on the ends protecting the pins. I don't exactly have 20/20 vision but these covers looked like a proper part of the cable and there was no mention or picture anywhere to alert me otherwise, so similar n00bs beware.
. HDD goes in cage which slides apart then back together with magnetic pins in the screw holes before sliding back in to the case. No tools and simple to use, took out the other cage for now so that the cables from the PSU are more comfortable in the space underneath, otherwise it would be a bit of a sharp turn. Video card straight forward and as you can see a good few cm to spare for some of the longer cards available. Also started to figure out some better cable routes, for example the ones for the buttons and lights going out the front and back in next to the fan to keep out of the side window. The USB header from the H80i pump went under the motherboard near the PSU to keep it out of the way. At some stage I thought it would be a good idea to put the fan I removed from the back in as a bit of extra help. It's mounted in the top as an extra intake. At the moment I'm justifying it as being a benefit blowing down onto the video card but I might try without at some stage for to see what the change is with noise/temperature. As I might have mentioned I probably will try to get round and see how the cooler differs as intake.
