So I've bought a Q6600 with a Arctic Cooling Freezer 7 Pro. An Antec 900 case. Geil Ultra PC-6400 RAM. All sat on an ASUS P5E board.
So far so good.
My overclock so far:
FSB 430 Muliplier 8: 3.45GHz
Vcore 1.30 (starting at 1.224)
RAM voltage: 2.1V
Timings 4-4-4-12 Ratio 1:1
Temps using Core Temp:
Prime95 small FTT - max 51 degrees, Blend - max 47 degrees
Mobo temp read by Asus 30 degrees.
Now I've tried increasing the FSB to 440, but can't load into Windows. I've slackened the timings, increased Vcore to 1.35V, increased the RAM voltage but all to no avail - I suspect its the RAM holding my back.
However, even with a multiplier of 9 I struggle to get over an FSB of 380 without the computer getting rather miserable.
So have I reached the natural ceiling for my CPU despite good temps? Or should I struggle on? Or should I just be a happy that everything runs nice and fast, and pretty cool, and leave it at that?
And long term, so as to give the CPU a more normal shelf life, should I run the CPU at stock more of the time?
Cheers in advance! Hope I don't sound too much of noob
So far so good.
RAM voltage: 2.1V
