My apologies, they look different to the ones I got, just judged from the picture in the item description they were the same - which they aren't. The fittings I got were a dark nickel. Those look like they have either been stored poorly or the plating is of a poor finish.
The value fittings I got had a really course thread on them, made getting a bite on the thread really easy which is why I suggested them.
In which case, I would suggest going for the EK fittings
I most definitely agree. I assume that is rust?
To be honest if it means waiting and saving a while longer I would rather get quality components that are going to last.
Great,not keen on the case but I have no doubt there are plenty others to choose from.
YOUR BASKET
1 x BitFenix Shinobi XL Full Tower Gaming Case - Black £104.99
1 x EK Water Blocks EK-FC670 GTX - Acetal CSQ £64.99
1 x XSPC RS360 120mm Radiator - Black £49
1 x EK Water Blocks EK-Supreme LTX - Plexi £29.99
1 x EK Reservoir Combo DCP 4.0 £24.98
1 x OcUK Tube Cutter Aluminum 3-14mm £8.5
2 x Mayhems X1 Clear Premixed Watercooling Fluid 1L £7.99 (£15.98)
2 x XSPC 7/16" ID [16/11mm] High Flex Hose - Clear £2.99 (£5.98)
1 x OcUK Value PSU Bridging Connector (24 Pin) £1.3
8 x OcUK Value 16/13mm 1/2"ID- 5/8"OD Compact Compression Fitting G/4" Thread - Silver £1.2 (£9.60)
Total : £333.00 (includes shipping : £14.75).
Need to add a pump, there's only a res listed ther
you so dont need a tube cutter.. im sure he has a sharp knife or such lying around.
indeed, but 8.50 is a waste if money is tight.
