The subject and beginning of the post both say 'gaming'..?![]()
Lol, yeah, i'm being an idiot.
You should spec in a better gpu if you spending £800. 670 is decent, much better than the 560.
i know you play bf3 and nvidia is better for bf3 than amd, but the gtx660ti isnt out yet, so for your budget, you could get a 7950 rather than a gtx560ti
http://www.anandtech.com/bench/Product/550?vs=547 <- comparison
tweaked a few areas
YOUR BASKET
1 x VTX3D HD 7950 X-Edition 3072MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion £259.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £173.99
1 x Intel 330 Series 120GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail £80.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £79.99
1 x Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM (ST31000524AS) £61.99
1 x Silverstone Strider Plus 500W Modular '80 Plus Bronze' Power Supply (SST-ST50F-P) £58.99
1 x Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9) £35.99
1 x Xigmatek Asgard Pro Gaming Case - Black £34.99
1 x Cooler Master Hyper 612S CPU Cooler (Socket LGA1366/1156/1155/775/AM3/AM2+/AM2) £32.99
Total : £834.01 (includes shipping : £11.75).
true, if op wants to spend 6 quid more ;p
the hsf is trash, so i wouldnt even count it in lol
6 quid for an extra 2 year warranty for a part that would 99.99999% not fail, idk...maybe for the extra peace of mind i guess
but only if op keeps the receipt and box! ;p
ahhh so many decisions...thought this was the fun part....well if you have unlimited budget I bet.
To cut price down, I will not get the 1TB Optical Drive and use the one in this system as I only need 500GB, dont need a huge amount of space as I dont play that many games.
I been debating to go for Gigabyte windforce Geforce 670 but the price tag does scare me.
So heres what its now come down to.
3rd Generation Intel® Core™ i5 3570K 3.40GHz Socket LGA1155 - Retail- £179.99
GIGABYTE GA-Z77-D3H Intel Z77 (Socket 1155) Motherboard - £86.99
ZOTAC GeForce GTX 560 Ti 448 1280MB GDDR5 - £179.99
corsair vengeance low profile 8gb (2x4gb) ddr3 pc3-12800c9 1600mhz dual channel kit - £35.99
intel 330 series 120gb 2.5" sata 6gb/s solid state hard drive - retail - £80.99
Seagate Barracuda 7200.12 1TB 32MB Cache Hard Drive SATA 6Gb/s 8.5ms 7200rpm - OEM - £68.39Corsair CX 600W V2 ATX2.2 80 PLUS® Power Supply - £54.98cooler master hyper 612s cpu cooler - £32.99******** Prowler Midi Case V2 - £29.98
TOTAL: £750.29 inc VAT - £625.24 exc VAT
Have to say mate that a ATI 7850 is a better card and they overclock very well.
Gigabyte 7850 - http://www.overclockers.co.uk/showproduct.php?prodid=GX-100-GI&groupid=701&catid=56&subcat=411
How to get a 7850 past 1050MHz - http://forums.overclockers.co.uk/showthread.php?t=18389760
And get a modular PSU for better cable management.
Finally, don't try linking to competitors.
Thats correct, only the cables you need are used and thus in a small case its easier to keep the cabling tidy and improve airflow.
This PSU is fine for that setup and either a 7850 or GTX560ti 448 - http://www.overclockers.co.uk/showproduct.php?prodid=CA-167-CM&groupid=701&catid=123&subcat=1103
7850 review (BF3 results) - http://www.guru3d.com/article/amd-radeon-hd-7850-and-7870-review/21
All test runs have enabled:
DX11
Ultra mode
4xMSAAAA enabled
16x AF enabled
HBAO enabled
Level: Operation Swordbreaker
We test at Ultra quality mode, should your graphics card have severe issues running in this configuration, by all means select a lower quality level or disable MSAA, 4xA MSAA will cost you almost a third to half your framerate. The chart above shows various cards in 1920x1200.
