Hello all, came for a bit of advice on one of my GPU's - as in my sig says I run crossfire 7950's (until middle of last week), Diablo 3 expansion was released last Tuesday and that's pretty much all I've been doing - on Tuesday after a few hours playtime my pc froze up and had to be restarted, took this as a sign from the heavens - it was getting late so I thought nothing of it, next day I got the same problem, playing for a while then pc froze - now I payed attention - their was some artifacting this time before the pc froze up - screen went blank and needed to be restarted so I had a look and noticed that my top gpu seems to be getting worse
(I have posted before that the gpu looks to be coming away from the fan - http://forums.overclockers.co.uk/showthread.php?t=18538068 )
and it seemed worse than when I took those pics, so I took the top 7950 out and have been playing peacefully since last Wednesday without any freezes or lock ups, today I decided to see if it was the 7950 acting up or something else in my rig - so I loaded up firemark extreme (best thing I could think of that quickly stresses gpu) and put the suspected working gpu (the gpu Ive been using from last Wednesday) through it twice - no issues, I swapped out gpus and tried the one I think has been having issues and the results:
1st test - bad artifactiing and crash almost immediatly
okay so I have the card O.C'd. perhaps its just this so I used the default settings (clocks)
2nd test - going good - got through the first stage and was on gpu test 2 on firemark extreme - then blank screen and no dvi signal on monitor- had to restart pc
3rd test - default clocks but fan speed at 100% - passed firemark with no issues
4th test - kept default clocks but turned off the 100% fan speed again - exact same result as test 2 - 2nd gpu test in firemark then no dvi signal and required restart and even after 2 restarts (with the pc apparently on) no screen display
So it looks like this is my 1st failed component - where do I go from here? the card was ordered on 16 Sep 2012 and I'm not 100% sure what sort of warranty came with it - think it might be 2 years but not 100% - any advice would be greatly appreciated
- Doco.
- Doco.
- took your advice and posted in C.S. Section, just have to wait and see
