hi guys,
Well as you can see this is my first post on here and i was wondering if you could help me with my first build because i need to know if it is all compatible? and the cooling will be sufficient etc
well heres my basket on OCUK:
Belinea 1925S1W 19" Widescreen LCD Monitor - Black/Silver (£117.49)
Seen Here
Samsung SH-182MRSMN 18x18 DVD±RW Dual Layer Lightscribe ReWriter (Beige,Black,Silver) - Retail (£21.14)
Seen Here
OCZ GameXStream 600w Silent SLI Ready ATX2 Power Supply (£70.49)
Seen Here
Sapphire ATI Radeon X1950 Pro 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (£99.86)
Seen Here
Antec Nine Hundred Ultimate Gaming Case (£70.49)
Seen Here
Corsair 2GB DDR2 XMS2-6400C4 TwinX (2x1GB) (£78.71)
Seen Here
Asus M2N-SLi Deluxe (Socket AM2) PCI-Express DDR2 Motherboard (£72.84)
Seen Here
Arctic Silver 5 Thermal Compound (3.5g) (£7.04)
AMD Athlon 64 X2 Dual Core 6000+ 3.00GHz (Socket AM2) - Retail (£110.44)
Seen Here
I think the only thing i'm worried about is wether the Graphics card will work well with the Mobo? and if you can see any other compatability issues then please tell me. also will the power suply be sufficient enough? can you find a cheaper one than that?
[Edit] also what will happen if i buy a PSU that isnt powerfull enough, because i have just been on (http://www.extreme.outervision.com/PSUEngine) to calculate the voltage required and it said 591 :O should i get a better psu?[/Edit]
Sorry if this is in the wrong section.
Many Thanks, Dan
Seen Here
Seen Here
Seen Here
Seen Here
Seen Here
Seen Here
Seen Here
Seen Here
Many Thanks, Dan
750w is better.
