I have a E6400, Asus P5B Deluxe, Geil 2Gb 800Mhz Ram, HIS 1900XT 512Mb
I am o/c for the first time and have been stepping up througout day and have got to 3.2Gz on air using Sythe Ninja and using . Currently running CPU Burn-In and the temps are showing as 57C (CPU) and 33 (System) - taken from Asus AI Suite
Core speed 3.2, multiplier x8, bus speed 400Mhz (taken from CPU-z)
Voltages are 1.544 CPU and 2.1V for Memory the PCI-E is showing as N/A (not sure what that is) in the AI Suite
What are these temps like for my set up?
So far I have only run COH Performance test, next I will run 3D Mark 06
I don't really want to push any further and will probably lower to around 2.8Ghz but will the 6400 go any further and still retain stability?
Cheers AB
Cheers AB
