I have been interested in the world of overclocking for a while, but never invested much in cooling so never went into the deep end before. So i bought a Corsair H50 and i have some questions!
Anyway my rig.
i7-930 Clocked to 4ghz (DO revision)
Corsair H50 Water cooler.
OCZ Reaper 6GB.
Antec 1200
Antec CP-1000 PSU.
Asus P6X58D-E
GTX280
etc.
Heres my rig and airflow
So the H50 is setup on push/pull venting INTO the case as instructed in the manual. I have a single fan above the corsair pushing out, the big fan on top pushing out, and the three fans at the front pushing IN. The PSU fan is pushing air out. GtX280 is stock and is blowing air down into the case.
All of the fans are stock Antec 3's apart from the corsair fan.
My current bios is like this.
CPU Ratio: 21
Speedstep: Enabled
Xtreme Phase Full power mode: Auto
BLCK: 191
DDR3: 1531mhz
DRAM timings are 8-8-6-24
Vcore: 1.318v (In CPUZ its 1.312v)
DRAM is 1.65v
QPI/DRAM: 1.34375v
Loadlinecalib: Auto.
Using prime95 at these settings running at 4ghz i record temps of 79C at its highest peak and on average 78C. Its a relatively stable overclock. I believe HT is enabled (Thought not sure where to check to see if its true?)
Anyway, my questions!
How does my setup currently look to the more experienced people? Anything i should change in my fan placement?
Should i buy better fans?
I have room for another fan on the side of the PC, which i could use as exhaust, should i do this?
Anything i should change with my voltages? As i feel i am running a tad high on the Vcore. However any less and its unstable.
I used the thermal paste the H50 came with and seemed to spread nicely, however i do have an unopened bottle of AC5 should i reinstall the H50 with this paste?
In the bios there is a setting for Xtreme Phase Full power mode, which is supposedly better for overclocking, would turning this on mean i can run less Vcore?
Anyway my rig.
OCZ Reaper 6GB.
Antec 1200
Antec CP-1000 PSU.
Asus P6X58D-E
GTX280
etc.
CPU Ratio: 21
Speedstep: Enabled
BLCK: 191
DDR3: 1531mhz
DRAM is 1.65v
QPI/DRAM: 1.34375v
