My First Overclock. C2D E6300/4CoreDual-VSTA
12 May 2005
Stoke, UK
Hi all,
So I pulled off my first overclock today and got my E6300 running at 2GHz, now I was hoping somebody would able to help me boost it a little more.
I have only been uping the Bus Speed, and I managed to get it 285MHz, if I go any higher on boot the system halts at the post screen after stating "Dual Channel Mode".
I am using the GeIL 800MHz Low Latency DDR2, the one thats currently 58.74 at overclockers.
Any help would be great.
Thanks
Matt
Think your mobo has reach its limit, VIA chipset never was famous for high FSB overclocks. Raise your north bridge chipset voltage if you have the option otherwise there is not much else you can do I'm afraid.
The Asrock tops out at around 300 FSB.
I suspect that it is the memory settings that are stopping you from getting there. Set the timings manually and you may get that last little bit.
Thanks for the advice, I will take a look at those, I have read about them before and didnt have a clue what the article was on about, but maybe i will understand more when in practice.
Thanks
Matt
from my old Dual-VSTA (similar board), AGP & DRAM volts to high, PCI-E freq to 110 or 117 might help
i maxed out at 302Mhz FSB ORTHOS stable.
should be some more info on overclocking here:
http://forums.anandtech.com/messageview.aspx?catid=29&threadid=1960908&enterthread=y
(big thread though)
apparantly with a few volt-mods you can get even higher....
*edit*
Motherboard Asrock-775dual-vsta
Cpu Intel-E4300
Memory OCZ Platinum Pc6400
Video card ATI X1950Pro Agp
Cpu heatsink Ocz VindicatoR
Chipset heatsink Swiftech MCX159-CU
Video Card Heatsink Accelero X2
Bios Settings....
Advanced:
Overclock Mode - CPU,PCIE Async.
CPUFr. - 320
PCIE Fr. - 117
PCI Fr. - 34.78
Spread Spectrum - Disabled
Boot Failure - Disabled
Max CPUID Val. - Disabled
Intel Virtuali. - Disabled
CPU Thermal Thr. - Disabled
No-Execute Memory. - Disabled
Intel Speedstep - Disabled
Chipset:
Dram Freque. - Auto
Flexib.- Disabled
Cas Latency - 3
Interleave - 4-Way
Precharge - 4
Tras - 12
trcd - 4
trfc - auto
trrd - auto
trtp - auto
twtr - auto
twr - auto
Bus Select.- Dual
Command Rate - 2T
Advanced Memory... all default
Advanced Host Conf:
Pipeline DRQCTL - Enabled
all other default
DRAM Voltage - Normal
AGP Voltage - High
Primary Gra.Adapt. - Agp
AGP - 8X
AGP Fast Write - Anable
AGP Aperture Size - 256MB
AGP Staggered delay - auto
AGP GADSTB - auto
V-Link - Normal
PCI delay Transaction - Disable <--- if anable Audigy wont work
IDE Drive Strenght - normal
PCIE Downstream Pipeline - Auto
Onboard LAN - enabled
Onboard Sound - disabled
ACPI - default
IDE - default
PCIpnp - default
Floppy - Disable
Super IO - all disabled
USB Conf. – default
that was with volt-mods, but thos setting should be good up to 300Mhz ish
