My first Overclock CPU
29 Feb 2012
London
Hi Guys im going to try and OC my 2700k for the first time.
Its currently running at 4.6 but i want to take it to 5
Has the sandy bridge guides been taken down?
Ive also never OC a cpu before so want to give it ago im using custom
Water cooling so it should go alright. Any tips or help ill update with results
Thanks
You bought this as a pre-built and overclocked system?
Which motherboard are you using?
Edit: Your sig just appeared there. What are your temps like with the current overclock?
