My first overclock..need help
Jaffa_Cake said:
fair enough well ive gone back to 2.4ghz at 1.5v..when i get my new ram would i be able to get away with running it at 1:1 or at least 5:6? the ram i got is:
Corsair Platinum Series XMS PC3200 1Gb
i never actually thought of that but if i can run the 2x512 kit at a faster speed than i wont keep the kingston...if not ill keep both..
i guess ill do it that way then..my ram at the moment is in the 3 slot..id be ok with sticking the other two in the 2 and 4 slot right?
You might find running more than 2 sticks of RAM might limit your overclock, as it puts more strain on the memory controller but this isn't always the case. A nice 2x 1GB matched kit would be the best option to give a nice all round speed boost.
