My First Overclock Results
22 Mar 2007
Just finished overclocking my CPU for the first time, an E6600. Got it to 3.4GHz stable on orthos, should I try pushing it a bit further?
Temps on idle are:
CPU - 41 degrees
Core 0 - 33 degrees
Core 1 - 33 degrees
This goes up when in Orthos to:
CPU - 63-67 degrees
Core 0 - 61 degrees
Core 1 - 61 degrees
Is this too high? Should I think about dropping it a little bit or is it ok at the current level?
Thanks
Vcore is 1.42v, and was stable for 6 hours on Orthos (I stopped it manually, would have kept on going ok). Just to be on the safe side, and because the summer is almost upon us, I've dropped it to 3.2GHz, temps down to 32degrees idle which is more like it, doesn't go above 60degrees even when running Orthos now so am happy with it as it is.
