Hi guys. Thanks to some great advice I recieved on here, I've bought myself and made up a brand new rig which I'm hoping will enable me to overclock somewhat.
First of all, here's what I purchased:-
CPU: E6600
MB: Gigabyte GA_965P_DS3P
HSF: Noctua NH-U12F
HD: WD Caviar 500GB 5000AAKS
PSU: Corsair HX 520W
RAM: Crucial Ballistix 2GB 5300
GPU: BFG Geforce 8800 GTS OC 320MB
As I mentioned, everything is built and it seems to be running smoothly, so I'm wanting to explore my overclocking options and work out exactly what I need to do.
Before I do anything, can you give this screenshot the once over? It shows my current CPU-Z and Speedfan readings, so I want to make sure that everything is as it should be before I get started. Can someone explain exactly what the CPU-Z readings are, i.e the temp1-3 readings? I presume the HD0 reading is the HD and Core 0/1 are the two cores of the Conroe? Do the temps look OK?
If everything is well, I want to start overclocking. I'm aiming to the get the FSB up to 400mhz, taking the memory with it up to 800mhz and the CPU up to 3.2ghz with a 8x multiplier. What kinda increments to do I need to go in?
Cheers folks!
CPU: E6600
HSF: Noctua NH-U12F
Cheers folks!
