Good morning all, This is my first post, so apologise if it is in the wrong area, Mods, please move if you feel it should be somewhere else!
Ok, I have been reading about building a PC for a few months now, and finally bought all the bits and bobs, from overclockers last week. Putting all the bits together was easy, following advice from on here (well easy, still took me about 4 hours! as i tip toe'd around the motherboard)
Anyway eventually got everything fired up (after an hour of nothingness, as i had forgot to actually power the cpu, yes please laugh guys and gals!)
Here is what i bought, and underneath some questions!
Seasonic S12 600w silent ATX 2.0 power supply
Windows Vista Home Premium 32 bit edition
Samsung SH-S182D 18x Dvd re writer
BFG nForce 680 socket 775 PCI express DDR2 mobo
Intel core 2 Duo E6600
BFG Geforce 8800 GTS
Western digital raptor 36gb
OCZ 2GB PC2-8500
Akasa Mirage 62
Now as i say i have it all set up, HOWEVER a couple of issues, that i am really struggling with!
The Akasa case can connect to the Mobo for sound, however the parts on the mobo board are named different to the parts on the case, so has anyone attached them together?
Case
R-Ret
R-out
l-Ret
L-out
Mic-power
Mic-in
Ground
Mobo
Port1_L
Aud_GND
Port1_R
Presence_J
Port2_R
Sense1_Return
Sense_send
Empty
Port2_L
Sense_return
Any ideas how i connect these up?
Secondly, i bought Norton Antivirus 2007 and cant get it to load on Windows Vista? i tried the Norton site but no joy?
Thirdly, I want to use some of the tools for the MoBo Ntune etc, but when i try to load them to vista, and then access them it says that i am not an administrator? even though i am in the user settings!
Any help would be appreciated!
Cheers
Jamie
OCZ 2GB PC2-8500
Akasa Mirage 62
Case
R-Ret
R-out
l-Ret
L-out
Mic-power
Mic-in
Ground
Mobo
Port1_L
Aud_GND
Port1_R
Presence_J
Port2_R
Sense1_Return
Sense_send
Empty
Port2_L
Sense_return
Cheers
Jamie
you can also set this permemnatly in the properties -> compatibility section on the right click menu.
