My first Pc Build
18 Jan 2018
Hey guys im building my first ever pc for £650 and im not very familiar with all of the parts so I so professional advice if the parts are suitable together and any recommendations to substitute any parts.Thanks in advance, the parts are listed below.
Parts:
msi gtx 1050ti 4gb gddr5 128 bit memory
corsair vengeance lpx 8gb
cooler master hyper 212
toshiba p300 1tb 7200 rpm
corsair spec alpha
corsair cp-9020049 80 plus 450w
gigabite ga-b250m-ds3h 7th gen intel core
intel core i5 7400
Welcome!
Good luck with the build, however, you would need to post this under the correct forum.
General hardware would be a better place to start. I will ask to get this moved for you :)
Do you want to build it yourself or want it prebuild?
Also do you need the operating system, monitor and peripherals? You saying "first ever pc" implies you need everything from scratch?
Parts:
corsair spec alpha
intel core i5 7400
You don't need that H212. The 7400 is a non K CPU and includes an adequate heatsink. Make sure the RAM you are buying is DDR4 as I notice you haven't listed it there.
I suggest you use the site part picker uk, as it has a compatibility feature, so it'll only show you parts that fit together.
Slightly over . gigabyte for UK RMA center along with excellent rep support on here, Nd naturally from OCUK whom you deal with first for any issues .
SSD for Windows install and 500GB for any games
Ryzen Board that will allow you to upgrade as time goes on and performs just as well as Intel
My basket at Overclockers UK:
Total: £680.58 (includes shipping: £11.70)​
could you suggest a build with a intel processor ?
my hard drive is 1tb and the same price
i got a bootable usb i got a monitor and keyboard mouse and stuff i have a pc but its really old I said I building my first pc.
is
the i3 overclockable? or could i switch it for an i5 and the one 8gb stick is cheaper than the one you're showing me
is
K versions are overclockable - unless you get expensive z370 that have BLCK chips to over-ride intel coding on the chips
if you need to save cash, i3 and then in a few years i7 8700k second hand. i3 will have a tough time over coming the stigma of its 4 cores now and not the same performance before, which is much much better then i5 7400 you mentioned above .
ryzen holds the best upgrade path though, and all chips are OC if user has lower priced B350 or higher costing X370 boards
