My first piercing
5 Jun 2007
extremes.spacious.indelible
Got scaffolding done in my left ear today, got two small bars in at the moment as ive got quite small ears, but going to go for a single bar when its ready :)
Just rushing out now, pics to follow :)
Awesome, I was thinking of getting this too, but I'm also having a second plug above my first and can't decide just how much **** I want in one ear :p
Needs pics ;)
Ditto! You should be able to put a single bar in there in about 5 or 6 weeks when it's reasonably well healed. I had one in from the start though.
Had to do same thing, wasnt sure what it was. They look cool tho, had all mine removed now but did have this in my ear:
resize_show.asp
which was followed by this, tho everyone has these now a days.
Got my Industrial done over a year ago, took ages to heal properly, was pierced straight away with the bar.
Did the person pierce one side, remove and put the first bar in, then the next one, or do them both at once, remove and put the bars in?
Ta-da!
The guy pierced both holes then put the bars in.
He said that the top one bled a lot so it took a while for him to clean it up and get it in, then clean it up.
Was in there for about 10-15 mins i would say? :D
i *love* scaffold piercings
but from previous experience i can almost certainally tell you that you will struggle to get a 'straight' scaffold through there
look at the angles of the two smaller bars - they dont align!
they may well do when they're healed tho - look after them and don't remove the bars too soon!!
I *had* one of these (vertical industrial) until the top 'hole' healed up during an operation.
I love the lower conch percing tho, it's probably my favourite!
I'll agree with that, you migth strugle to get a full bar to fit comfortabley now. I don't understand why he would have done that, looks ok to have put the bar in straight away.
