Hey guys, pics of my first build! Cable management isnt too easy in this case but i plan to make the hole next to the power supply bigger
so i can route them behind the mobo tray. Pic 4 shows where the wires are currently stashed, there seems to be a rather unhelpful plastic
tray in there which wont come out for some reason aswell...also in the top right of pic 5 you can see the inadequite hole already supplied,
it really needs about 2 cm more to be of any use, this is what i plan to do, good idea? any other suggestions?
