yeh both fans are spinning at 100% on the radiator! ive plugged the h50 in directly to the psu through a 3 pin converter! so my guess is that its number 3! if i take the h50 off will i be able to put it back on without new paste? since i havent got any here and really need it ;(
thanks for the help by the way its much appreciated
you should be ok with the paste if your careful not to rub it off. In an ideal world you should have some on standby.
If you don't want to take it right off maybe just loosen it, swivel it around a bit and then tighten it up again... the main thing is to get it even.I do opposite screws a few turns each and so on.
Also just check your molex to 3 pin for the pump... some are low fan speed i.e. 5v instead of 12v designed for silent running fans
