- 30 Apr 2007
Hey all, I plan on building my own rig in the next week or two, and as you lot seem to have a near infinite knowledge, what better place to aim all my questions and queries!
Right. I'm going to be using the PC for lots of media (films, music), and gaming. I want the PC to handle Oblivion, C&C3, BF2, and Crysis when it comes out. Though, it doesn't have to run them at top spec, just a decent level. My budget is around £700. Ignore monitor, keyboard, mouse.
So, my spec is something like this...
Intel Core 2 Duo E6420 "LGA775 Conroe" 2.13GHz (1066FSB) - Retail - £129.24
Zalman CNPS7000B-CU Ultra-Quiet CPU Cooler - Retail - £22.31
Gigabyte GA_965P_DS3P (Socket 775) PCI-Express DDR2 Motherboard - £88.11
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit - £82.24
BFG GeForce 8800 GTS OC 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - £190.34
Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - £58.74
Pioneer DVR-112DBK 18x18 DVD±RW Dual Layer ReWriter - (Black) OEM - £21.14
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK) - £70.49
Creative Sound Blaster Audigy SE 7.1 Sound Card - OEM - £18.79
Antec Nine Hundred Ultimate Gaming Case - £64.61
Total: £746.01
REMARKS:
Firstly, yes I realise this rig is almost identical to another on another thread, but hey, I think it fits my needs perfectly.
I don't intend on overclocking it, since I've never delved into overclocking before. But... tbh I can only assume I will be in 6 (or 4 or 2 or 1) months time.
QUESTIONS...
Will the E6420 do? I was considering the E6600 for a long time, but it's quite possible that the E6420 will be sufficient for my needs.
Motherboard/Memory - good choices? I was considering Corsiar memory, bit more expensive, but you guys seem to praise the Crucial (plus on sale). Also, I was considering the Intel DP965LT 965 (Socket 775) since it's cheaper, but is it worth getting the Gigabyte?
Graphics - hmm I really don't know whether it's worth shelling out for the 8800GTS, I know the 8600 range is a bit pathetic for what it's worth, but getting a high end DX9 card would bring the price down a fair bit, which would be nice. 8800 would no doubt find its way next year or so.
PSU/Fan - Sufficient? And quiet? I would appreciate a quite system a fair bit.
Any opinions on the OCZ GameXStream 600w Silent SLI Ready ATX2, as it was another choice?
Soundcard - I imagine this is good enough... is it worth shelling out a bit more for the X-Fi range? (considering I want to keep the price down)
Case - This seems to be a popular choice... I can only assume it's good?
Oh yeah, and just a quick mention of the monitor... Asus widescreen 19".
Right, I reckon I'll keep this thread going throughout my whole build process, as no doubt I'll have a lot of questions. I've helped my dad build PCs before, but not build one solely on my own.
Thanks so much for all help in advance!
Total: £746.01
REMARKS:
QUESTIONS...
), RAM looks good, GPU looks good, HDD looks good, PSU looks good.
My god you guys reply quickly!
Its not bad if you get the drivers setup correctly.
) - but should I still go with it, despite it being almost £10 more now? (it's now £88.11)
