My first "spec me"
27 Jul 2007
...How very exciting :)
So I am in desperate need of a new PC, and I am quite smitten with the idea of a small case after years of dealing with the behemoth that is the Fractal Define XL.
I have the following components that I would like to re-use:
1) Crucial M4 256GB SSD
2) 4 x 4GB Kingston ValueRAM KVR1333D3N9K2 DDR3 DIMMs (datasheet)
3) Sapphire HD 7850 OC Edition
I have a Corsair HX520 PSU too, but I'd like a new one that is Haswell compatible.
My requirements:
1) Intel 4670K CPU
2) A stable motherboard. I am coming from a Supermicro board so this is very important.
3) Bitfenix Prodigy or Phenom case. I like them both, but I am torn between ITX and MATX for reasons I'll explain below.
4) Space for 1 x SSD and 2 x HDD. I need 2 x 4TB WD RED drives included in the spec.
5) Space for a full-length graphics card.
6) Silence. I think Antec have new PSUs out where the fan stops if there is minimal load?
7) A good, thin mousepad!
What I don't need:
1) No operating system, monitor or peripherals.
2) A "theme". I do not care about the internal aesthetics of my computer (bar tidy cables), and I definitely do not want fans with LEDs.
3) Complicated water cooling. I did all of that 10 years ago and hated the hassle. The sealed water coolers might be of interest if they don't require any maintenance.
I am torn between ITX and MATX for the following reasons:
1) The PSU and HDD placement in the ITX Bitfenix cases is really nice, but I do want to use a modular PSU.
2) In order to install 2 x HDD in the MATX cases, it looks like I'll have to sacrifice the two fans at the bottom of the case.
3) MATX allows me to install 4 DIMMs.
4) I like the placement of the graphics card in the MATX case, since it's at the top which seems like a good idea for cooling.
I don't have a budget, but I'm expecting this to cost roughly £1000-£1100 with the 4TB drives.
If you made it this far and didn't fall asleep, I applaud you :)
Thanks!
I thought you guys would be jumping up and down to help me spend money :)
So I'm thinking something like this:
YOUR BASKET
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £239.99
2 x Western Digital Caviar Red 4TB SATA 6Gb/s 64MB Cache WD40EFRX - OEM HDD £154.99 (£309.98)
1 x Gigabyte Z87M-D3H Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard £97.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £94.94
1 x BitFenix Prodigy M MATX Cube Case - Midnight Black £74.95
Total : £817.86 (includes shipping : FREE).
Tempted to go for the Gigabte GA-Z87MX-D3H instead, but OCUK don't stock it. If I use two graphics cards, I assume that I can't use a water cooler?
Speaking of which, I'm not sure about spending £95 on a water cooler. Are there any good air coolers that will fit? I also need help with case fans, please :)
I need help choosing a power supply too. I want it to be very quiet, and be able to support something silly like a HD 7990 in the future.
My RAM will work in this board, right?
How does this look?
YOUR BASKET
1 x Corsair RM Series RM 650 '80+ Gold' 650W Power Supply (CP-9020054-UK) £99.95
1 x Phanteks PH-TC12DX CPU Cooler - Blue £44.98
1 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) £25.99
1 x Corsair AF140 Quiet Series Low Noise High Airflow - Single Pack (CO-9050009-WW) £14.99
1 x Arctic Cooling MX-2 Thermal Compound (4g) £6.98
Total : £605.82 (includes shipping : FREE).
I'm torn between air cooling and the refurbished Corsair H100. I feel like I would have to change the fans on the H100 to reduce the noise, and then it would be a lot more expensive than a HSF.
I removed the hard drives from my previous basket because OCUK are out of stock. So in addition to this basket, I have 2 x 4TB drives and 1 x SSD to install, as well as 4 x 4GB Kingston ValueRAM KVR1333D3N9K2 DDR3 DIMMs (datasheet).
I need to order a new graphics card too, but I'm waiting to see what AMD and NVIDIA release this month. I need something that maxes out BF4 at 1440p.
Any opinions would be appreciated because the CPU is only on special for this weekend :)
CPU is good - I've ordered one myself.
Get AF120 fans for the top instead of the SP120s, and a 230mm for the bottom.
For cooling I wouldn't go for a h100i as you'll not be able to use a second graphics card, which sort of (but not entirely) defeats the point of going for the mATX over the ITX. The h80i would work just fine. Can't go wrong with Noctua air coolers, though.
Personally, I'd get some new RAM. OcUK have some excellent deals on this week.
Your motherboard doesn't support SLI, so bear that in mind when choosing a GPU.
Not sure about the mATX prodigy, but you don't have to install HDDs on the bottom of the Phenom M.
Where can you mount 3.5" drives in the Phenom other than in the bottom?
You can put them on the other side of the support bar-like thing that you use to mount SSDs.
Also: didn't realise Corsair did LED versions of their AF series :eek:
I wondered if the inside of the SSD mounting beam was an option.
Pre-Order. I only just found them myself.
Aren't they awesome :D
Also I assume you can still fit 2 fans in the top with 2 GPUs installed?
Added 2 dual packs for the top and bottom :)
Thanks guys :)
I had forgotten, but you can mount the 3.5" drives to the back of the cage that slots infront of the CPU:
As Fulax says, this will allow me to place a 230mm fan at the bottom of the case.
I do want SLI/Crossfire to be a possibility, but the PSU concerns me. This page on BitFenix's site says that cards longer than 11" require a 150mm PSU. The specs for the Corsair RM650 says that it is 150mm, so I think it should fit. Oceaness, I'm sure 550w isn't enough to run a 4770k and two cards? Would 650w cut it?
How does this look?
YOUR BASKET
1 x Corsair Hydro H80 High Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Guarantee £34.99
1 x BitFenix Spectre 230mm Fan - Black £11.78
Total : £566.64 (includes shipping : FREE).
The motherboard is a placeholder because OCUK don't sell the Gigabyte GA-Z87MX-D3H which supports 2 x PCI-E 3.0 8x. The Asus Z87 MAXIMUS VI GENE also does 2 x PCI-E 3.0 at 8x, so I can't really see how it is worth £60 more. I'm going to stick with my existing RAM for now, because I've read some comparisons between 1333Mhz and 1600Mhz RAM, and it seems like it will make very little difference to the performance.
I wish I could find a site that confirms this!
Looks like it, yes.
Any idea how two LED AF120s would compare to a single 230mm Bitfenix Spectre in terms of noise and performance? For the bottom.
The RM 750w is only £10 extra, and would suit you just fine. Unless I'm being retarded, though, OcUK don't seem to have it listed any more :confused:
EDIT: The h80i performs much better than the h80, by the way.
Honestly not sure about the 2 120's vs the 230. The Bitfenix 230mm just don't seem to look as good to me though.
Thewanted, you are right, I've changed the PSU, you need a 750W+ for 2 cards.
Yeah, I couldn't see it either :(
Are you sure it will allow me to have 2 cards installed? The Corsair site says that the dimensions for the RM750 are 150mm x 86mm x 180mm.
EDIT: I see that the Corsair RM750 is listed as "Pre-order" on another site, so stock must be low. Argh!
The Seasonic 750W I spec'd is probably a slightly better PSU and dimensions are
L = 160mm
W = 150mm
H = 86mm
I just saw that on their site, thanks!
New basket:
YOUR BASKET
1 x Seasonic G series 750w '80 Plus Gold' Modular Power Supply £119.99
1 x Corsair AF120 Quiet Edition Low Noise High Airflow - Dual Pack (CO-9050002-WW) £19.99
Total : £606.67 (includes shipping : FREE).
I added the non-PRO version of the 230mm fan because the PRO version seems quite loud. You'll also notice that I added the quiet versions of the AF120s too.
Any thoughts on my choice of motherboard (Gigabyte GA-Z87MX-D3H) and cooler?
I think the corsair Fans I spec'd are the same as the quiet versions, just a new LED version of them I think, cause they're on pre-order. The specs both say about 24/25 db.
I'm using an H80 refurb myself :) It's pretty good. However a couple of Scythe GT 1850's are practically a requirement. The stock fans are very loud.
Only reason I went with the Asus board is because it fit with the red theme ;)
Thanks oceaness, but I'm not bothered about a theme and I definitely don't want LEDs :(
The H80 + 2 x Scythe GT 1850 fans seems about as expensive as going for the H80i that comes with SP120s already attached. Would the Scythes be much quieter than the SP120s?
Sorry for all the questions! :)
No probs, just wanted to make sure you weren't just losing them because you were worried about noise :)
The SP120Ls the H80i comes with are high performance ones, not low noise. I think the GT's are much better.
Cool, that's good to know!
I think I've made a final decision:
YOUR BASKET
1 x BitFenix Phenom MATX Cube Case - Midnight Black £74.95
Total : £646.76 (includes shipping : £11.75).
I swapped the case to a Phenom M. I'm still torn!
After watching this review of the SP120 and AF120 fans, I will use the SP120s for the H80, and the AF120s for the case because that's what they're designed for. The Scythe Gentle Typhoons are quite expensive and don't seem massively better than the SP120s. I appreciate the suggestion though!
Stupid question, but how will I get 5 fans to work off this board if it only has 4 fan headers?
