My first twenty miler. Now my second twenty miler as well!
Commissario
16 Oct 2002
In the radio shack
I know many of you will do this before breakfast but this was a big one for me - My first twenty mile ride.
Most of it was along combined public footpaths/cycleways so my average speed wasn't very fast. Being a Sunday, there were a lot of people about so the bell got a good airing to alert slowbies that I was behind them.
I Stopped a couple of times to take some pictures and drink some water but then some total dingbat on a bike moved directly into my path right at the bottom of a hill forcing me to brake down to a stop very quickly - Because I'd been giving it some, I was in a high gear so I ended up walking up the hill because I couldn't get the momentum going to be able to change down the gears to something I could actually pedal. He was very apologetic but must have been either deaf, stupid, ignorant, or all three because I was dinging away like mad as I approached him so that he'd look up and keep clear *sigh*. Apart from that, I didn't stop at all.
I used to cycle everywhere as a kid, just getting back into cycling. After a couple of getting used to the saddle rides and getting comfortable, I've done 7 miles and 10
Groin and butt discomfort kick in before anything else.
I don't know where that max speed has come from, I can't find it as I scroll through the ride on Strava and I don't remember going that fast anywhere. I suppose I could have but I just don't recall it.
You can see whereabouts if you go on Analysis on the Strava web app. Quite likely you did hit that really as it's pretty easy going down a hill and it's unlikely to feel super fast.
I'd already done that but couldn't find it - I've just zoomed right in to see where it's logged and it's clearly a GPS blip as that bit is flat and the trace thinks I've just leaped from the track over to the road.
On the being stuck in a high gear thing - you could have just stood by the bike, lifted the back wheel, and changed down whilst turning the pedals with a foot or hand.
Or stay on the bike with one foot on the ground, change gear, put the front brake on and lean forward to lift the rear wheel, then turn the pedals over with your other foot.
Easier with clipless pedals, but doable on flats.
Well done dude,i remember my first 20,only had my road bike a day with clip on shoes,the next day i done a 50 miler,was a eye opener to me and was not prepared one bit,got the same ride coming up in 2 weeks,i now know what to expect and will be 100% prepared :)
Last time I went out for "twenty miles" I got dragged around an extra 80. So well done on being restrained :D
I can't really remember my first 20 miles... but I do remember doing 25ish, and averaged about 12 mph... and was dead for about a fortnight.
What was your GPS device?
Strava running on my phone, in my pocket. I'm going to be getting a Garmin 520 which I'll nail on the handlebars.
Good shout lads, that's something so obvious but it just doesn't go through the mind at the time.
Heh, no plans to do a fifty mile ride just yet but I'm sure it'll come.
...and was dead for about a fortnight.
Heh heh, I'm fine today. If it's going to hit me, it'll be tomorrow.
I remember being amazed I could even ride that far in one go.
I knew I could do it, I did eighteen miles last weekend. It was a nice feeling though. I did plan my route on purpose to be particularly flat ;)
i found my iphone used to do something similar. randomly it would plot me in the middle of a field. one of my colleagues did a 10k run recently and his iphone read a couple hundred more meters distance than another runners garmin..
definitely wouldnt go back to a smartphone since getting my 800 :)
My Garmin arrived on Thursday and I fitted it all to the bike yesterday so this morning I went for a ride. I made the stupid mistake of pausing it to make a couple of changes to the settings and forgot to restart it for a couple of miles so this is shorter than it should be. Is there an auto-pause/resume hidden in the settings somewhere?
A very similar route to last weekend, I just went further by road to start with to get a greater distance away along the sea front. Dreadful headwind for a big chunk of this but then of course I benefitted from the tailwind on the return part of the ride.
It's amazing how different things report different calorie burns. Garmin Connect and Apple workout both say over 1200 but Strava says 540. The Garmin has speed, cadence, GPS and the heart rate strap and Apple workout has GPS and the wrist HRM.
Could easily have ridden further because I was far from exhausted but I've got things to do today.
Garmin should auto-pause by default but it may be hidden in bike/activity settings.
If you have put correct height/weight/etc data in Garmin Connect then it should have the most accurate kcal estimate by far when use use an HRM. That said, in this case the Strava total sounds right.
Feel free to add me on Strava if you want me to look at your rides a little closer :) https://www.strava.com/athletes/3808469
