hi all have posted a lot over the weekend and learnt a lot for every one so thanks i am looking at getting into water cooling and did not want to get a kit so went for a custom set up entry level only for first go lot to learn i think i am water cooling a amd £3.9ghz am3 processor and just want some advice if thie following set up would be up for the job
XSPC 1/2" Clear/UV Blue tubing
CODE: TBXSCB/12
Quantity: X £2.89 x4m
Feser 1/4" BSPP High Flow 1/2" ID - 3/4" OD Compression Fitting
CODE: TFC-COMP12
Quantity: X £3.89 = £31.12
Yate Loon 120x120x25 D12SL-12+4LED 1350RPM Blue LED
CODE: D12SL-12+4LED Blue
Quantity: X £5.10 = £10.20
Phobya DC12-260 12Volt Water cooling Pump
CODE: DC12-260
Quantity: X £32.99 = £32.99
PrimoChill PURE Performance Coolant (32 oz.) - UV Blue
CODE: PURE UV Blue
Quantity: X £8.25 = £8.25
EK Supreme LT AMD - Plexi (754/939/AM2+/AM3)
CODE: 3830046990129
Quantity: X £30.64 = £30.64
Barbs: None Required 2x 8/10mm compression (+£2.98) 2 x 3/8 Compression (+£5.98) 2x 3/4 Compression (+£5.98) 2x 3/8 Rotary Compression (+£5.98) 2x 3/4 Rotary compression (+£5.98) 2 x 3/8 Barbs (+£3.38) 2x 3/4 Barbs (+£3.98) .Unfortunately this combination is not accessable.
XSPC RS240 Radiator - Black
CODE: RS240B
Quantity: X £34.99 = £34.99
XSPC Single Bay Reservoir - UV Blue
CODE: BR525UV
Quantity: X £19.99 = £19.99
CODE: TBXSCB/12
CODE: TFC-COMP12
CODE: DC12-260
CODE: PURE UV Blue
CODE: 3830046990129
CODE: RS240B
CODE: BR525UV
