Hello all first of all i would like to apologize about the photos! Im useless with a camera.
Anyway, this is my first watercooling project and my aim was to house all the cooling in the case. First off I needed a bigger case (did have a antec 900) so I bought a Lian Li V1110b off the members market. Case arrived in fantastic condition thanks (Deluxe1).
After a lot of head scratching and trying to work out the best way to place everything this is what I have come up with.
My first aim was to sort out where the rad would go, so out to the shed to grab the jigsaw.
Rad Grill will be arriving tomarrow.
Then I cracked on with the side panel from this
To this
Bought some trimming to finish it off, this is what it looks like on the case
Not a lot of progress going on at the mo, I'm still waiting on parts. This is how the case stands atm.
As you can see i have mounted the pump upside down as i didnt want it on view in the window.
I the next few days I will be fitting the rad - grill then adding the tubing, im going for a red and black theme, red dye and black coil. will keep you updated.
To this
