on tuesday i managed to get my new watercooling loop setup, as it was my first i had asked around a bit on what blocks to get and what order things should go in.
Waterloop Kit:
Swiftech Apogee GT CPU Block
Swiftech MCW30 Chipset Block
Swiftech MCP655 (DD D5 Vario)
120x3 Alphacool Nexxos pro Radiator
Alphacool Cape coolplex 25cm External Reservoir
7/16" Masterkleer Tubing (5/8" OD)
Rest of Spec:
C2D E6300 @ 3.2GHz
2GB GeiL Low Latency Memory
Gigabyte DS3 Motherboard
8800 GTS 320MB Graphics
200GB Maxtor HDD
Antec P180 Case
the case is w3bbo's old P180 modded with the rad attached to top and window cut into side panel.
My idle temps havent changed but load temps have dropped by 10c
Old Temps: With Titan Amanda TEC Cooler
Idle: 38
Load: 73
New Temps: On Water
Idle: 37
Load: 62
Waterloop Kit:
Rest of Spec:
C2D E6300 @ 3.2GHz
200GB Maxtor HDD
Antec P180 Case
Idle: 38
Load: 73
New Temps: On Water
Idle: 37
Load: 62
