My friend PC please help
23 Mar 2011
Hi guys
I have a bit problem with my mate pc, he purchase build tower for £800 which I told he's mad for what he's got, spec:
Amd FX 8350
16 Gb unbranded ram
EVGA 660ti the one that runs at 915mhz clock
2tb hard drive sata
600w chines power supply
some crapy tower that don't have proper USB3 cable from front panel to connect to motherboard,
CPU cooler fan is about 50mm and when you run anything just sound like it won't to take off, not sure if he can return this or not but I did advise him that he get in touch with people who he got it from and send it back, if they don't accept this what would you recommend changing it???
I was thinking good power supply like corsair or XFX or seasonic, then nice cooler for CPU, I'm not expert on AMD cpu's but from my previous knowledge AMD runs hotter then intel? He's not to bothered about the tower at the moment.
The whole system runs sort of slow and unresponsive, can you help, also he did like the close loop water cooler from Corsair or another brands but are they better then air coolers.
