Bri said:Can anyone spell LAG![]()
1CE said:Is that a 2l lump?
Virdi said:Once I was told - That these funky Manifolds are for better flow... But I was also told that they are supposed to be 'Equal Length'..??
God knows - lol
Trinity said:Basically, for uber performance you want the gas squabs to run in the same formation that they leave the block in (1,4,2,3) for instance. If that happens here, squab one is going to collide with 4 before its even reached the Turbo.
Is it a hybrid turbo?
penski said:On a naturally-aspirated engine, yes.
In reality, turbocharged engines can literally get away with absolutely shocking manifold designs.
The only design consideration is if the snail has a split input...In which case you'd split the fannymould ensuring that the pulses arrive sequentially.
*n
Ah yes, jus remembered where I heard that, PPC. If the manifold on their BMW turbo project works then the chances are you could probably chuck something together from a few straws.penski said:In reality, turbocharged engines can literally get away with absolutely shocking manifold designs.
*n
burns said:Ah yes, jus remembered where I heard that, PPC. If the manifold on their BMW turbo project works then the chances are you could probably chuck something together from a few straws.
[TW]Fox said:Nice engine, shame he's going to waste it on a horrible old Escort. Either do it properly old skool and put it in a Mk2 or something, or pick an actually half decent car to put it into, rather than an old banger.
