- 18 May 2009
Well here are the parts that i am about to order! Please tell me what you think it will be like and rate it out of 10 if u wish
Specs:
- MSI 790GX-G65 AMD 790GX (Socket AM3)
- XFX ATI Radeon HD 4890 1024MB GDDR5
- Scythe Kaze Master Ace 5.25inch Fan Controller
- PC Power & Cooling Silencer 750 Quad-Crossfire PCI-E 750W Power Supply
- Corsair XMS3 4GB (2x2GB) DDR3 10666C9 1333MHz TwinX Dual Channel
- Western Digital WD5000AAKS 500GB SATA II 7200RPM 16MB Cache
- AMD Phenom II X4 Quad Core 955 Black Edition 3.2GHz
- Titan Fenrir CPU Cooler
- Antec 900 gaming case
- Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter
- Akasa Dual Blue Cold Cathodes
- Akasa AK-191-SM Smoke Ultra Quiet 120mm
- CIBOX C2202 22'' Widescreen TFT 1680x1050 1000:1 300cd/m2 5ms
- Akasa Fan Filter - 120mm - x3
So just tell me what you think and also if you like it
Thanks!
EDIT: Also im not sure which is a better PSU? The one i listed or Tagan TG700-U25 700W ATX2.0 Dual Engine Silent SLi Compliant Silent PSU i do plan to crossfire in the future!
Specs:
Thanks!
