My gfx card is too large to put my capture card next
1 Oct 2019
Hey all, ideally I don't want to have the expense of buying a new board.
My gfx is a 4090 and almost covers the pci slot next to it, is there any sort or angled adapters?
I'm sure I'm asking a stupid question but I'd like to use my capture card but not buy a new board (current board is MSI mpg x570 gaming pro carbon)
Don't think so, either new board or buy an external capture card that uses USB.
Could use a riser cable but its not ideal as it won't be securely fastened in the case unless your case has an insane amount of room to mount it with a riser.
A riser might actually, the case has loads of room to secure, I'll see if there's room to get one in, thanks
If your case has a separate section to mount a vertical mount you could use a riser and mount it that way, provided the GPU isn't too wide and takes up that space. Without knowing what case you have, we can't advise any further.
