My google powers are weak :(
22 Aug 2010
On the Wagon-East Angular
I'm trying to find the instructions for a Midland SWR-25 swr meter, but am unable to find any.
I know how to use the swr meter, but I've forgotten what side goes to the tx and what side goes to the antenna :o
I'd be really grateful if someone could help and find some instructions/wiring diagram - many thanks - quink :)
A pic of the meter
I think I have one at home, I can check and see if I still have the manual when I get back if you like.
Cheers, but that's just a general guide for using a swr meter - I'm unsure which socket is which on my swr meter :)
There's a slightly different model manual here
I'mn afraid it's in Polish, but I can't access from here :o
Cheers - that Polish one is slightly different - I'm 90% positive the tx goes into the left socket and the antenna to the right - there are no markings on the meter :rolleyes: There will be once I've found out :D Thanks Gilly
