It is in sig. anyway this says max. 64 watts for GPU, so adding the other components of the card what would that be? Be nice if PNY gave the power needs of the card.
Minimum 450W or greater system power supply (with a minimum 12V current rating of 24A)
Minimum system power requirement based on a PC configured with an Intel Core i7 3.2GHz processor.
SuperFlower Golden Green HX 350W "80 Plus Gold" Power Supply - Black
A 200w PSU, if you could find one, would be enough. In fact, the one which comes with the element q is enough
you mean dual slot? im sure you could get a single slot card with that spec?
Ya, well I just got this card a few months back. So there are no Element Q type cases with 2 slots on the back huh?
