My h50 temps what do u think ?
31 Jan 2011
Hampshire
im using Core temp and prime 95
idle temps are about 36c
Stress test getting about 43c on core 0 1 2 and 53c on core 3
how do these temps sound ? no overclock yet
Not to bad, start overclocking and keep your vcore low as possible whilst remaining stability.
mine defo running warmer than yours, im @ 1.280v in cpu-z 4.1ghz and the hot core is at 60c the other 3 are at 48c funny thing is the rad is pretty cold to the touch
Just installed the H60 in mine, had a quick run with my i7 920 (10 mins prime 95) System temp was 39c and CPU hit a max of 58c - Not sure if this is any good as I didnt check the temps before! DOH!.
It is however now basically silent :D
Getting the temps from the Asus AI-Suite, I'm assuming this is fairly accurate
