Hello.
I have made custom LED lights on one of the walls in my hallway but unfortunately they have stopped working and I cannot find the cause for it. I have 3 metres of SMD 5630 LEDs (144 LEDs per metre) cut into 6 strips that are connected individually to a WiFi Bluetooth controller which is then connected to a LED power supply.
Here is my quick diagram:
I have tested the 240v input with a probe and it definitely shows live electricity, output from the 12v WiFi controller also shows power. Strange thing is I have decided to test the LED power supply and connected it to one of the wall sockets, surprisingly it works so that eliminates a faulty power supply, controller or any other fault with the wiring.
Could this be a fault with my home electric box? LED power supply is wired to a circuit breaker where all the other home lights are wired into. I will mention these lights worked for a about 6 months with no issues.
