Caporegime
- 1 Dec 2010
- Welling, London
OK, so I have known for a long time that my Q6600 with 8800GTS just cannot cut the mustard any more, so moved forward with an average, but fairly capable build. Luckily the cost came down slightly as I was able to re-use some components from my old PC.
To Start. Old PC and shiny new case
An empty Obsidian 650D
After a bit of demolition work, I had my salvage parts ready
Started. PSU and drives first to go in.
Once that was done, the motherboard and CPU went in, followed by the RAM.
The design of the case left me able to fit the cooler while in the case which was very handy. Cooler was soon on, but I did find the last part of installation where you have to twist the cooler into the retention plate a bit fiddly. Had to do it a couple of tims, so will watching my temps in case there was a thermal paste problem, but all good so far.
When I look at this picture now, the PC looks a little precariously perched
Pretty much done and dusted then. Just some cabling and a little tidy up and I was left with.
The cabling at the bottom is not great. I'll see what I can do there.
A close up of cooler and RAM. Think the Kingston Hyper X looks great with the Extreme 4
Another View
All finished!
You may notice there is no graphics card. I will update this thread as soon as one goes in. I am just waiting for prices of the 560Ti to fall slightly.
Specs:
i5 2500K
ASRock Extreme 4 Gen 3 Mobo
8GB Kingston Hyper X
Corsair HX620 modular PSU
Antec Kuhler H20 620
1TB & 250GB HDD's
Corsair Obsidian 650D
One question for anyone. I have a spare Corsair fan. Can that be used with the Kuhler in a push/pull config to improve cooling?
Another View
All finished!
Specs:
i5 2500K
1TB & 250GB HDD's
