1st off all hi all im new here
2nd my build is ideally a gaming rig.
Ok this is a basic look at a build im thinking of making so asking for abit of advice to see if its ok and such and to ask a few questions.
so here goes this is my idea for a build i may want but i maybe wont buy to about october as i really want to wait for windows 7 as xp may not be able to run future upgrades and im not to keen on getting vista after all the bad press. Also other fans maybe a option to add to the case im abit unsure on water cooling at the moment thou the door is open.
Also before i ask questions my monitor is a 24" acer G24 incase this makes a difference to the build.
My questions are
1, is this compatable an stable ??
2, I kind of wantto go with SSD only and have no other drives apart from my external my book 500gb. Is SSD really that much faster than traditional Hard Drives that this is a good idea ? (also to add i feel in the future when SSDs are a lot cheaper an bigger i can add 1 more then).
3. Is the power supply powerfull enough ?
4, My other option is im thinking of almost same build but the Intel Core i7 975 3.33Ghz or 965 3.20ghz then OCZ or dominators DDR3 PC3-16000 range. But unsure of how well over clocking can be done with all these or if its worth it ?.
5. If i did want the i7 965 or 975 and the DDR3 PC3-16000 range ram would overclockers be able to build this rig and overclock it or is it abit earlie as its so new ?.
Also im looking to possibly spend about £2000 up to maybe £3000 at extreme thou it would have to be worth it
so far thats all my questions i may have more thou i cant think of any more at the moment. Ive always built most of my own pcs so have always had abit of knowledge on things thou i think its better i ask and research more. An overclocking myself at the moment is something i think i shouldnt try to ive learned abit more.
My questions are
. so far thats all my questions i may have more thou i cant think of any more at the moment. Ive always built most of my own pcs so have always had abit of knowledge on things thou i think its better i ask and research more. An overclocking myself at the moment is something i think i shouldnt try to ive learned abit more.
