Hi,
I've had the iPod classic 80GB I think for about a year, and its been fine untill now. I did install this thing called MGTEK dopisp, so I could use windows media player to sync the iPod, which worked but it's a trial.
I then installed iTunes, and sometimes the iPod will not show up on iTunes, unless I manually reset the iPod by holding menu and the middle button for seven seconds. Also, theres some songs I bought, imported into iTunes, and they will not play on the iPod even though they work on iTunes and any other player for that matter. I even tried to sync them on an old iPod Nano which worked fine. Whats wrong with my iPod Classic?
What I've tried to far it creating a new library, updating iTunes to 9.0.3a nd restoring the iPod, none fixed the problem..
What I did notice is with the songs which don't play, if I load them into FL Studio, and save again the exact same name and mp3 format 320kbps, load into iTunes, it works fine on the iPod Classic..
Help!!
Help!!
