- 18 Mar 2012
- Eastbourne
Hey guys!
I'm going to have two kinda builds running through on this thread. One is my ITX build, nothing special, just thought i'd add it in as i'm rebuilding my main PC with a WC loop, properly this time!
The ITX Build:
The only reason i'm building this is because I won the case from OcUK at i55
Also all purchased from them too!
YOUR BASKET
1 x Gigabyte GeForce GTX 960 OC 4096MB GDDR5 PCI-Express Graphics Card (GV-N960OC-4GD) £154.99
1 x ASRock B85M-ITX Intel B85 (Socket 1150) DDR3 ITX Motherboard £65.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £59.99
1 x Intel Pentium K Anniversary G3258 Socket LGA1150 Processor - Retail £55.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD38G1600HC11DC01) £44.99
1 x BitFenix Colossus M Mini ITX - Black £39.95
1 x Kingston 60GB SSDNow V300 Drive SATA 6Gb/s 3 2.5" (7mm height) Solid State Hard Drive - (SV300S37A/60G) £34.99
Total : £456.89 (includes shipping : Ex.VAT).
It's all done, up and running without the 960 though.
Main PC rebuild: All components staying the same just adding in a water cooling loop.
So the Spec of my PC is in my sig.
Here it is as it stands:
The loop parts:
YOUR BASKET
1 x EK Water Blocks EK-FC Titan X - Acetal+Nickel £89.99
1 x XSPC D5 Vario (Body + Screwring) £54.95
1 x EK Water Blocks EK-D5 X-RES 100 CSQ - Acetal £49.99
1 x XSPC EX280 Dual Fan Radiator £40.99
1 x EK Water Blocks EK-Supremacy MX £34.99
1 x MagiCool Copper Radiator III - 360 mm £32.99
2 x Monsoon 19/13mm (ID 1/2 OD 3/4) Free Center Compression Fitting Six Pack - Blue £24.95 (£49.90)
1 x EK Water Blocks EK-FC Titan X Backplate - Black £22.99
1 x Mayhems XT-1 150ml Clear Coolant £6.98
2 x Primochill Primoflex Advanced Tubing 19/13 - White £5.99 (£11.98)
Total : £395.75 (includes shipping : Ex.VAT).
I will be swapping out the normal tubing and going for hardline when funds allow and putting the gpu in the loop so it'll be finished hopefully by the end of the week but will be updated overtime to get it totally finished.
I didn't buy them fittings and res size out of choice, they were on the MM for cheap so i thought it's good enough to get me back into watercooling as my H105 is on it's last legs
The ITX Build:
Also all purchased from them too! YOUR BASKET
The loop parts:
YOUR BASKET
, I love how cute Itx boards look next to graphics cards and coolers lol!
