Howdy! Long time no see. Ain't posted here for a while!
So yesterday my kraken G12 arrived and so did my new H115i (for my cpu) Thank you OCUK <3
I had already been using a H110i on my CPU which is compatible for the kraken G12 so i decided to water cool my RX580, and it wasn't just for show, the RX580 ARMOR edition has one of the worst coolers i have ever encountered. theres numerous threads all over the internet about there card's throttling when fans are on 100% and mine was one of them even undervolting and slowing the card down at 100% fan speed (which sounded like a turbine) it would throttle back.
There has also been a lot of debate if a kraken G12 fits the rx580 armor, and YES IT DOES!
Also, i have a Corsair 750D, which with a H110 and a kraken, you can't fit the 280 rad in the front as the tubes wont reach, So i had to mount it in the floor in the 240 area, BUT it doesn't fit, so i had to dremmel part of the case away as you will see in the pictures, I highlighted in red the area i dremmeled out.
And another thing, i can only run one fan on the rad with it floor mounted, But as you will see its more than enough.
So without further a-doo heres my picture log !Large images! Click spoiler to view.
From the pictures above, the orange straw was just to keep the card straight and level =D haha.
The results:
2500k I5 @ 1.45v 5ghz,
CPU DUSTY H110 Fan speed 50% IDLE 55 / LOAD 83
CPU With New H115i Fan speed 25% IDLE 43 / LOAD 65
RX580 ARMOR
STOCK @ 100% Fan speed - IDLE 55 / LOAD 90 then throttling.
Kraken g12 H110i with 1x fan @ 25% speed @ 1.575GHZ 1.25MV - IDLE 22c(Roomtemp) / LOAD 45c / Furmark 50c
3dmark Benchmarking:
Im absolutely over the moon with the results, I now have every single fan in my pc (They are quiet edition fans anyway) but they are running @25% speed on my controller and the whole system is silent and iv never seen gpu temperatures like this before.
It was pretty straight forward and simple to do installing the kraken, and also now i have this amazing cooling solution ready for any upgrade (up to rtx 2080 etc) sat ready for anything i throw at it.
Also as a final note, Does any one know a program that i can push past 1.25MV core? as my sliders are maxed out in afterburner. TY!
Ty for reading, Hope you enjoyed reading![/spoiler]
The results:
RX580 ARMOR
